So my Daewoo Puma 6 just decided to throw this code, svo13, and the machine will not reset and come on. The code is z improver v ready off. I have read a couple other post about this code and I have checked my fuses and they all look like they are ok but I am lost from here. What else do I need to be checking to see what is causing the code? And if pictures of my boards would help just let me know and I will post them.
I faced with this alarm couple of times, the problem was in contactor (inside the drive) contacts. you may swap the PCBs with another drive and take a look what happens, but don't forget about settings on PCB (jumpers, switches)
and if you see that swapping PCBs doesn't help, then try to replace contactor
