Need Help! Lost parameter
Results 1 to 11 of 11
Thread: Lost parameter
    Mar 2018
    Macedonia, The Former Yugoslav Republic Of
    Default Lost parameter
    We have Centrum 2000 i think we have problem with parameters ,if somе оne have answer for this one problem please help us
    whеre found and,how can put parameter
    Beast regards
    Feb 2018
    South Africa
    Default Re: Lost parameter
    Hi Bobimik
    What model Fanuc control do you have ?
    Is your machine turning or machining centre
    Mar 2018
    Punch turret press from Murata WidemannLost parameter-4-jpg
    We have alarm 914 ram parity (servo)
    SYSTEM ERROR 0130-03
    Attached Thumbnails Attached Thumbnails Lost parameter-4-jpg
    Oct 2005
    INDIA
    is your machine booting ? if yes then...
    Record All existing Parameters....DGN Screens, All Programms in detail....by taking clear Photos of each screen....or video .
    shut down the machine....
    Hold "0" + Del key ....start the machine......all parameters will be erased.....!
    Re-Enter the parameters...manualy...or if you have backup / SRAM ...load it from it.
    Mar 2018
    I do not know how to record the parameters my screen is frozen ,
    we have same machine want to ask if the two Machine have the same parameters
    оr whether it's possible to find the original parameters for the machine
    thank you very much
    Oct 2005
    INDIA
    Quote Originally Posted by Bobimk View Post
    thank you very much
    oh sorry ....did not see the picture earlier.
    which machine is this ?
    except some parameters ....most of the parameters from similar machines are almost same.
    try "0" + del and see if system boots properly.
  7. #7
    Mar 2018
    I I tried with 0 + del some parameters have lost some of them myself
    now report me more alarms, please for further help
    Lost parameter-33-jpg
    Attached Thumbnails Attached Thumbnails Lost parameter-33-jpg
  8. #8
    Feb 2018
    South Africa
    Hi Bobimk
    These alarms are due to axis software limits being zero.
    Check in your parameter list for the settings and punch
    them in.
  9. #9
    Member Lorenzop01's Avatar
    Jan 2020
    Hello,
    I have a Murata C2500 \CNC turret press, If anyone has the list of parameters and description, please send me a copy, also this machine will run perfectly fine all programs but with the "punch off" button pressed, if we try to punch it will position and right before punching it shows alarm 1013 which indicates that 2 sec. passed and the press didn't press, or that the break off sensor signal is not present, there is no break off sensor, there is a signal coming from the VS-5B controller, looks like everything is there but it will still won't press
  10. #10
    Jan 2020
    Hello,
    Do you happen to have a list of parameters for a murata CNC turret press, C2500?
  11. #11
    Dec 2015
    ?r whether it's possible to find the original parameters for the machine
    thank you very much
    Bobimk , if you have same machine no worries put the parameters in this machine all Alarms will clear and same machines have same parameters.
    quick-cnc
Lost parameter
Lost parameter
