Komo 510 MACH II, with Fanuc 21i-MA control (DNC from card reader)
My Fanuc control has very small on board memory and I am not able to run long programs on the machine. I have manual that talks about running DNC from the card reader that is on the control but I am not able to get that to work does anyone have instructions for this control to run DNC from the card reader?
Re: Komo 510 MACH II, with Fanuc 21i-MA control (DNC from card reader)
You can dripfeed from your memory-card by M198.
Mainprogram to cnc-memory, large data in sub-program on memory-card.
Call the sub-program by M198 (not M98) and don't use an extension for the file on the card, no TXT or NC, just O1234 !!!
Fanuc sells a nice ( cheap ) program that expands your memory up to 2GB with the PCMCIA-card adapter !!!!!!!!!!!!!!!!!!!!!!!!!!!!
It's called Fanuc Memory Tool Card Program Version 5.0 --- Fanuc A08B-9010-J700/ZZ11.
For good access to the BIN-file on the card Manual Guide i is recommended or necessary.
