Need Help! Fanuc G84 rigid tapping code - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 18 of 18
Thread: Fanuc G84 rigid tapping code
  1. #13
    Feb 2007
    Default Re: Fanuc G84 rigid tapping code
    Quote Originally Posted by m1n1m View Post
    My machine with a Fanuc Mate actually throws a error if I include a speed command (S) with the M03. The Fanuc post processor includes it tho so I have to manually remove it after each post..No idea if that solves anything for you tho ^*
    Thanks everyone for your help, the S400 and M03 above the M29 line was a big factor in the slowness for sure. With the M29 line the M03 is unnecessary. I had been using the S400 with the M03 with no issues or errors.
    Jack
  2. #14
    Oct 2015
    Let me know if you figure out how to remove this line before a rigid tap cycle. These are modal codes so I assume they have to be reset somehow before a rigid tap cycle. Will poke some at my post processor in a few days and see if I can figure out something.
  3. #15
    Feb 2007
    I have no idea what your talking about. Why don't you give me the tapping g code example.
  4. #16
    Gold Member
    Feb 2006
    india
    He is probably saying that the spindle is already running.
  5. #17
    Oct 2015
    Quote Originally Posted by Roadstercycle View Post
    I just assumed that you didn't want to manually edit your gcode after each post containing a rigid tap cycle so you wanted to edit the post processor to leave out M03 SXXX. Also if you had a S commanded earlier in the program it's modal (I think) so it will remain until set to another value. I just tested this the other day on my machine so I'm not very experienced with this.. There's not much of an example to give really. Your code will be good as long as M03 SXXX command is dropped on my machine but this is a bit machine dependent so it's not set in stone what format it needs.
  6. #18
    Feb 2007
    I manually do my coding. If I do use Fusion 360 then I tweak it. It's no big deal for me because I use the same code a lot. So it is stored.
