What is the next block?
Hi all,
After many years of programming Fanuc lathes at the machine, I took the plunge today to actually use the TNR comp. As I feared I have hit a problem. WIth a 0.8 mm tool rad, in T3 after facing off to Z 0.0 , I approach the work, G0 X32.0 Z2.0, THEN G1 G42 Z0.0. At this point the tool goes into the face, almost as it the compensation is too much. Hope that explains it enough. Any ideas why?
Pete , UK
I think you need to start lower, now the tip is at X26.5, so if you have 1.2 in nose radius start at x24.(0.1 clearance) But if you change to R1.6 it will plunge, but if you change to smaller it's ok.
A little tricky to start compensation on a chamfer you need to think of the nose radius of the tool, 30-(1.75*2)-(1.2*2)=24.1
G0 G42 X47.0 Z2.0
G0 X24.
G1 Z0.0 F0.1
G1 X30.0 C1.75
G1 Z-39.5
G1 X46.0
G0 G40 X200.0 Z200.0 T1000
Make sure that you have the correct nose number in the offset.
Hi
Yes its a 0.8mm tool nose rad, and quadrant 3
Hiya,
It's a 0.8 rad insert, not 1.2.
But from what you say it seems I have to allow for the tip rad in my x calculation? I.E 0.8 x 2 = 1.6 so 30mm - 1.75 -1.75 - 1.6 = X 24.9. If so, surely thats the point of the G42 isnt it? So I dont have to work this out?
Pete
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*______Please give to charity [url]https://www.oxfam.org.au/get-involved/______*[/url]
It's only where when you start you need to consider this, if you tell the machine to go to x26.5 it will undercut to make the chamfer.
Maybe you can do it like this instead, it will go under with the tool radius.
G0 X47.0 Z2.0
G0 G42 X26.5
G1 Z0.0 F0.1
G1 X30.0 C1.75
G1 Z-39.5
G1 X46.0
Glad it worked, i don't use compensation much because issues like this, but i never thought about starting compensation X start of chamfer, i always started compensation on Z so i always had to give it enough space in X direction before chamfer.
