parameters for setting up IO CHANNEL 0 is normally on the Handy page, hit the offset key multiple times.
I have an Amada Laser with a Fanuc 160i controller that I am attempting to connect with FabriTalk to. However going through the parameter setup I do not see the parameters for setting up IO CHANNLE 0 or 1 0101, 0102, 0103 when in PWE mode. Am I missing something, They were visible several days ago. The only parameter change has been setting from Tape type 3 to RS-232 Type 4.
An help or thoughts is much appreciated. Jeff
Is this a different screen that shows paramtet 0000 through 0100. It then jumps from 0100 to 0300.
I have a couple 160i controllers on Milling machines, maybe lasers are set up different. Can you post a picture?
I got it . It was actually on the System page. You went to the Handy and then hit system. Thanks for the help.
I use 9pin - 25pin Null Modem cable with a basic communication software. We sell a basic software if you cant find a free download.
Exec Memory Software/Multiple Control (API A8665) - Mounts & Retrofits | Alternative Parts Inc.
Why use a serial connection on an i-control? You can use the pc-card (next to the monitor) instead.
Thank you..... I totally forgot it was there. Set up controler and we are loading programs again..... Thank you for your help.
