Originally Posted by
drdos
You are going to need a lot of work to get this thing going. Not possible thru this forum as there are too many variables that need to be addressed. Not only do you need a ladder you will also need I/O interface to talk to the operator's panel. Do you even have an operator's panel? You need something to select which axis to jog, home and run in automatic mode. It takes me a week to accomplish this on a simulator with all the hardware in tact. Not only does the ladder need to be written, it must match your configursation. Also, the parameters I sent you are only a starting point. The servos need to be initialized for the motors you plan on running on this. Then we have Fanuc options that need to be turned on which Fanuc will have to come in and do. (That is why you can't see your ladder as the option bit for your ladder type is not set) Sorry but I am going to abort this mission.
