Ot-C, macros were no, now off. Also cannot turn on rigid tap. parameter set issue
2 problems I guess. Had macros on though never used them. My bits on these 900 parameters are set correctly I believe but now do not show up on control. This might have happened when I was trying to turn on rigid tap to see if it would work. control will not allow me to enter a bit in the corresponding 900 parameter for rigid tap so I put it back how it was.
graphics is still showing up but macros is a problem. Is there some other reboot I need to do here? leave turned off longer?
If you want to PM due to the options questions, no problem.
