Need Help! #2057 Turret Clamp Error(A9.1) and #2018 Turret Run Alarm (A4.2)
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: #2057 Turret Clamp Error(A9.1) and #2018 Turret Run Alarm (A4.2)
    Mar 2012
    Indonesia
    Unhappy #2057 Turret Clamp Error(A9.1) and #2018 Turret Run Alarm (A4.2)
    dear friends cnczone,
    I have a problem with my machine cnc turning fanuc,
    before lunch we used the machine no problem, We lunch and the machine turned off and after lunch appear operator message :
    first = no 2057 Turret Clamp Error (A9.1)
    and we try to change the tool, the turret only move just moment and stopped, in the display appear no 2018 Turret Run Alarm (A4.2),
    please help me, anyone know this problem ?
    thank's before.
    Rudi, Batam Islands, Indonesia Country
    Jan 2011
    You should write down all info concerning your machine. Anyways all corresponding valves and detectors should be checked, else maybe it needs reindexing, maybe the hydraulic/pneumatic pressure is wrong too.
    Mar 2012
    Indonesia
    ok thank you, I will try to checked the hydroulic system, some day ago the hydroulic pump any oil leak from side pump.
    Dec 2009
    ROMANIA
    check the cable from the clamp/unclamp sensor ,this cable is staying in a non good position and in time this cable will break and the sensor will not work.
    Mar 2012
    Indonesia
    dear friends,
    I checked hydroulic pressure,sensor,valve all ok,
    but I checked the driver motor turret FANUC A06B-6132-H002 the batterai should 6v but only 2,3v,
    the batterai any problem or still limit ok ?
    Jan 2011
    Crystal clear that your battery is NOT ok, that you should replace it and that you will probably have to re-index your motor as well. Is your machine a Hyundai lathe or what brand is it?
  7. #7
    Mar 2012
    Indonesia
    our machine is "GOOD WAY", ok I try to change this battery
  8. #8
    Dec 2009
    ROMANIA
    Default Re: #2057 Turret Clamp Error(A9.1) and #2018 Turret Run Alarm (A4.2)
    man do not do other things
    trust me
    go in the back of the machine were is the motor of x axes and there on the left you will see a snall white box with a wire in the plastic cover (i called copex cover)that cover has "U" form and because the x axis is going down and up houndreds of times ,the cable inside that cover is getting damage.
    that small white wire that goes in the box is the sensor for turret clamp.
    now the wire is broken and can not see turret clamp and that why is not turning the turret.in the diagnose the sensor is X3.0
    must be 1 when turret is clamped.
    i work everyday on goodway machines,we are dealers of GOODWAY so "go on my hand"
    there is a procedure to make turret reference
    if you want that too just tell me.
    after you finish with that if the tool no 1 is not coincident wit the number on the tool disc you have to reference the turret.
  9. #9
    Mar 2012
    Indonesia
    sir, I check the sensor turret ok and the turret in position. when we toolchange manual after press "tool" button shoul be turret move in front of and moving, but now condition after we press "tool" button, the turret move to in front of and go move back ( the motor turret not turn).
    I try check other =
    the servo amp. turret inside panel have 3 kinds alarm led indicator ( LED INDICATOR 4 LED GREEN ABOVE. AND 3 LED RED BELLOW)
    (1). LED GREEN no 2 and 3, LED RED no 1
    next
    (2). LED GREEN no 4, LED RED no 1 and 3
    next
    (3). LED GREEN no 2, LED RED no 1 and 2
    next back again to number (1)
    any problem with servo amp. turret ? or must be repair ?
  10. #10
    Dec 2009
    ROMANIA
    you need to zero return you turret
    give me an email adress and i will send you the procedure
  11. #11
    Mar 2012
    Indonesia
    this is my email : restuibu85@gmail.com
    thank you so much before for your help.
  12. #12
    Dec 2009
    ROMANIA
    email sent ,let me know if worked!
  13. #13
    Mar 2012
    Indonesia
    yes, succesfully. thank you so much.
    Good luck always.!!
  14. #14
    Registered Lonestarcnc's Avatar
    Nov 2014
    22114 Sixpence Lane
    Can someone send me the reteach procedure for turret on Yama seiki? I replaced batteries but I do not have procedure.
  15. #15
    Feb 2006
    INDIA
    Kindly send me too.
    ahe_303@rediffmail.com
    Quote Originally Posted by zavateandu View Post
  16. #16
    Nov 2010
    indonesia
    send me please, my email ( aaagt78@gmail.com)
  17. #17
    Can I have this procedure please.
    Thanks a lot
    thanhhaung@gmail.com
    Hau
  18. #18
    trust me
    Hi Zavateandu,
    Can you please share this procedure.
    My email thanhhaung@gmail.com
    Thanks a lot
    Hau
  19. #19
    Registered sansgp's Avatar
    Oct 2008
    singapore
    Dear sir,
    May i request with you for turret procedure?
    this is my email : sansgp@yahoo.com
    Appreciate your help. thanks.
  20. #20
    Can you please send me the zero return procedure?
    jared@graymachinery.com
    Thanks!
