what is the pmc type?
hi friends .,
please explain me how to open PMC.000 ( which is in different drive file saved thru sd card )fanuc ladder III software.
Run Fanuc ladder III, select file, open program, in the new window under files of type select all files, find the .000 file on your card and select it, then hit open, it should say memory card file selected hit OK, type a name into what the name field and hit OK, decompile should start allowing you to view and edit the ladder.
open file ***.lad with Fanuc ladder 3 then you can see PMC on parameter
just export the file ,not save.
