Just a guess, but:
I'd pop the fan/mag sensor cover and feel if the bearing is shot...the mag sensor is sensitive to gap, especially as they age and the magnets get weaker...if the rear bearing fails, you might feel the shaft wobble(loosen belt so shaft isnt bound) and if it does, the gap change will really screw with the motor...Ive seen chips stuck in the belt cause the shaft wobble every rev of the belt as the chip causes belt tension to vary... if the rear bearing fails, rust from fretting corrosion or even metal bits from the bearings can get caught in the teeth of the sensor ring, but usually youll get a klunk every rev.
if youve never changed a rear bearing before, a note of caution- dont pull the sensor ring off with a puller- its dead soft and will be ruined/stretched oversize... I just pull the sensor itself out of the way, protect the wires somehow from heat, carefully heat the areas between the holes on the ring with a torch, it will pull right off with just twisting/using a glove... if yours has the double sensor(outer one only has one groove for 1 rev pulse), mark the single groove thing relative the shaft so you can put it back in alignment, the 256 tooth ring wont matter, its just pulses for speed/direction... Ive changed rear bearings in the machine before, pretty easy if the fan end is out in the clear... also, measure the shaft position to the ring, they sometimes arent shouldered, so you have to reinstall them to roughly the same axial position- I think give or take 1/16 axial wont hurt much, its not super critical- just the teeth need to be somewhat in the middle of the sensor face...radial clearance is important, I usually set them real close, like a piece of paper thickness- seems to help with older sensors to run the gaps tighter than original... be REAL careful no chips/crap get stuck in the fine teeth of the sensor ring, a chip(or ding in the teeth) will mess it up...
edit- shoulda mentioned, if you have a scope, you can look at PA/PB feedback pins- if you see uneven sinewaves, might just need adjusted, but if you see wild amplitude spikes, Id suspect bearing... and if you pull the rear endbell to swap the bearing, watch out for the wavespring too- dont let it fall inside the motor
