You have to be in MDI, set PWE=1 and you must turn the KEY to ON (this is hidden in the opr alarm menu, opr soft key). I have the same machine if you have other question.
Just wiped out my memory and parameters. I have everything reloaded but I can't do anything because of 1008 d450 set err.
The control will not let me change #s in diagnostic d499 -d520 to fix problem. I have changed these numbers in the past but
I have to believe my problem today has something to do with reloading parameters. Hardinge mcv1000 Fanuc O MD control.
Machine is up and running. I had PWE=1 but I did not have key on.
Estimados buenas tardes, he perdido la información de parámetros , diagnósticos y macro, ya tengo los parámetros ,pero me falta el macro y los diagnósticos o llamados parámetros de PLC, alguien podría ayudarme. Se lo agradecería mucho.
the following is for umbrella type 20 tool automatic tool changer
diagnostic parameter:
N10300 P 11010000
N10301 P 00000111
N10302 P 01110001
N10303 P 10100110
N10304 P 00000000
N10305 P 00010100
N10306 P 00000000
N10307 P 11001100
N10308 P 01000110
N10309 P 00000000
N10310 P 10101110
N10311 P 00001000
N10312 P 10110000
N10313 P 00001000
N10314 P 00000011
N10315 P 11001010
N10316 P 00000000
N10317 P 01101000
N10318 P 00000001
N10319 P 00000000
N10320 P 00010100
N10321 P 00000000
N10322 P 00010110
N10323 P 00000000
N10324 P 00000011
N10325 P 00010100
N10326 P 00000000
N10327 P 10110001
N10328 P 00000000
N10329 P 00000000
N10330 P 00000000
N10331 P 00000000
N10332 P 00000000
N10333 P 00000000
N10334 P 00000000
N10335 P 00000000
N10336 P 00000000
N10337 P 00000000
N10338 P 00000000
N10339 P 00000000
N10340 P 00000000
N10341 P 00000000
N10342 P 00000000
N10343 P 00000000
N10344 P 00000000
N10345 P 00000000
N10346 P 00000000
N10347 P 00000000
N10348 P 00000000
N10349 P 00000000
N10350 P 00000000
N10351 P 00000000
N10352 P 00000000
N10353 P 00000000
N10354 P 00000000
N10355 P 00000000
N10356 P 00000000
N10357 P 00000000
N10358 P 00000000
N10359 P 00000000
N10360 P 00000000
N10361 P 00000000
N10362 P 00000000
N10363 P 00000000
N10364 P 00000000
N10365 P 00000000
N10366 P 00000000
N10367 P 00000000
N10368 P 00000000
N10369 P 00000000
N10370 P 00000000
N10371 P 00000000
N10372 P 00000000
N10373 P 00000000
N10374 P 00000000
N10375 P 00000000
N10376 P 00000000
N10377 P 00000000
N10378 P 00000000
N10379 P 00000000
N10380 P 00000000
N10381 P 00000000
N10382 P 00000000
N10383 P 00000000
N10384 P 00000000
N10385 P 00000000
N10386 P 00000000
N10387 P 00000000
N10388 P 00000000
N10389 P 00000000
N10390 P 00000000
N10391 P 00000000
N10392 P 00000000
N10393 P 00000000
N10394 P 00000000
N10395 P 00000000
N10396 P 00000000
N10397 P 00000000
N10398 P 00000000
N10399 P 00000000
N10400 P 00000000
N10401 P 00000000
N10402 P 00000000
N10403 P 00000000
N10404 P 00000000
N10405 P 00000000
N10406 P 00000000
N10407 P 00000000
N10408 P 00000000
N10409 P 00000000
N10410 P 00000000
N10411 P 00000000
N10412 P 00000000
N10413 P 00000000
N10414 P 00000000
N10415 P 00000000
N10416 P 00000000
N10417 P 00000000
N10418 P 00000000
N10419 P 00000000
N10420 P 00000000
N10421 P 00000000
N10422 P 00000000
N10423 P 00000000
N10424 P 00000000
N10425 P 00000000
N10426 P 00000000
N10427 P 00000000
N10428 P 00000000
N10429 P 00000000
N10430 P 00000000
N10431 P 00000000
N10432 P 00000000
N10433 P 00000000
N10434 P 00000000
N10435 P 00000000
N10436 P 00000000
N10437 P 00000000
N10438 P 00000000
N10439 P 00000000
N10440 P 00000000
N10441 P 00000000
N10442 P 00000000
N10443 P 00000000
N10444 P 00000000
N10445 P 00000000
N10446 P 00000000
N10447 P 00000000
N10448 P 00000000
N10449 P 00000000
N10450 P 00011001
N10451 P 00000000
N10452 P 00010000
N10453 P 00000000
N10454 P 00000000
N10455 P 00011001
N10456 P 00000000
N10457 P 00010000
N10458 P 00000000
N10459 P 00000000
N10460 P 00000000
N10461 P 00000000
N10462 P 00000000
N10463 P 00000000
N10464 P 00000000
N10465 P 00000000
N10466 P 00000000
N10467 P 00000001
N10468 P 00000000
N10469 P 00000000
N10470 P 00000000
N10471 P 00000000
N10472 P 00000000
N10473 P 00000000
N10474 P 00000000
N10475 P 00000000
N10476 P 00000000
N10477 P 00000000
N10478 P 00000000
N10479 P 00000000
N10480 P 00000000
N10481 P 00000000
N10482 P 00000000
N10483 P 00000000
N10484 P 00000000
N10485 P 00000000
N10486 P 00000000
N10487 P 00000000
N10488 P 00000000
N10489 P 00000000
N10490 P 00000000
N10491 P 00000000
N10492 P 00000000
N10493 P 00000000
N10494 P 00000000
N10495 P 00000000
N10496 P 00000000
N10497 P 00000000
N10498 P 00010000
N10499 P 00010001
N10500 P 00001000
N10501 P 00000001
N10502 P 00000010
N10503 P 00000011
N10504 P 00000100
N10505 P 00000101
N10506 P 00000110
N10507 P 00000111
N10508 P 00001000
N10509 P 00001001
N10510 P 00010000
N10511 P 00010001
N10512 P 00010010
N10513 P 00010011
N10514 P 00010100
N10515 P 00010101
N10516 P 00010110
N10517 P 00010111
N10518 P 00011000
N10519 P 00011001
N10520 P 00100000
N10521 P 00000000
N10522 P 00000000
N10523 P 00000000
N10524 P 00000000
N10525 P 00000000
N10526 P 00000000
N10527 P 00000000
N10528 P 00000000
N10529 P 00000000
N10530 P 00000000
N10531 P 00000000
N10532 P 00000000
N10533 P 00000000
N10534 P 00000000
N10535 P 00000000
N10536 P 00000000
N10537 P 00000000
N10538 P 00000000
N10539 P 00000000
N10540 P 00000000
N10541 P 00000000
N10542 P 00000000
N10543 P 00000000
N10544 P 00000000
N10545 P 00000000
N10546 P 00000000
N10547 P 00000000
N10548 P 00000000
N10549 P 00000000
N10550 P 00000000
N10551 P 00000000
N10552 P 00000000
N10553 P 00000000
N10554 P 00000000
N10555 P 00000000
N10556 P 00000000
N10557 P 00000000
N10558 P 00000000
N10559 P 00000000
N10560 P 00000000
N10561 P 00000000
N10562 P 10011111
N10563 P 00000000
N10564 P 00000000
N10565 P 00000000
N10566 P 00000000
N10567 P 00000000
N10568 P 00000000
N10569 P 00000000
N10570 P 00000000
N10571 P 00000000
N10572 P 00000000
N10573 P 00000000
N10574 P 00000000
N10575 P 00000000
N10576 P 00000000
N10577 P 00000000
N10578 P 00000000
N10579 P 00000000
N10580 P 00000000
N10581 P 00000000
N10582 P 00000000
N10583 P 00000000
N10584 P 00000000
N10585 P 00000000
N10586 P 00000000
N10587 P 00000000
N10588 P 00000000
N10589 P 00000000
N10590 P 00000000
N10591 P 00000000
N10592 P 00000000
N10593 P 00000000
N10594 P 00000000
N10595 P 00000000
N10596 P 00000000
N10597 P 00000000
N10598 P 00000000
N10599 P 00000000
Diag parameter are binary coded decimal
Some are machine state dependent:
#499 is the pocket of the tool changer in front of the spindle
#500 is tool number in the spindle
#452 and #457 are (#499-1)
Tool change macro:
O9020(TOOL CHANGE MACRO)
(REV2 5-98)
IF[#1015EQ1]GOTO50
IF[#20EQ#0]GOTO60
IF[#20EQ0]GOTO70
#1100=1
#106=BIN[#1032]
IF[#106EQ#20]GOTO45
M09
G80
M86
#101=#4001
#102=#4002
#103=#4003
G91G0 G30 Z0 M19
G17G91G80G0G49
M85
M82
M84
M07
G28Z0.
T#20
M07
G91 G30 Z0
M83
M88
M81
N30G#101G#102G#103
N40M87
#1100=0
M05
N45 M99
N60#3000=1(M06-NO-T-CODE)
M99
N50#3000=2(MACHINE/MST-LOCKED)
M99
N70#3000=3(T00-PRESS-RESET)
M99
