Allo!
We have a purchase a new CNC 4 axis lathe. This is essenstially 2 CNC controls running concurrently.
We also have a renishaw probe installed. Which uses a lot of Macro B to function. No problem there.
my question is if I probe with Turret #1 and stored results in a Variable, say #501. This variable is not available to Turret #2. It has its own Variable #501. In other words, it's like having 2 cnc's separately controlled. Mirror images of each other. So what could be done to "SHARE" some data between the 2 Turrets?
Are there some details on variables that I am missing?
Thanks!
Thank you much. Great help!
Sent from my HTC Sensation 4G using Tapatalk 2
It's possible to make a range of common variables shared between the 2 sides.
I had to do the same on similar control. We had to change a system parameter to do it.
I don't remember which.
Sent from my Phone 2 using Tapatalk
