Mike,
What type of help are you looking for?
Let me know,
Hi guys
Anyone have a fanuc 10m with 80m of tape memory, need your help. I have one with 40m of memory and can trade you for information on this. I have all option parameters for many control's (besides the parameter to increase from 40m to 80m on the fanuc 10m)
thanks for you time.
mike roy in canada
Mike,
Let me know,
JR Walcott
Georgia Machine Tool Resources, LLC
I have the add mem card along with all the chips that are required, don't know how to make 80m of mem happen. I install the card and only get 40m.
is there something i am missing.
mike roy
mroy7@cogeco.ca
1 519 337 0423
Have you checked your Parameters?
901.3 132ft Part Program Storage Length A : 40m
901.2 262ft Part Program Storage Length A : 80m
JR Walcott
Are you sure this is for the fanuc 10m
Hi guys
I have attached the machine spec sheet along with a quote that fanuc sent me. I have circled two numbers on the fanuc quote(one for 40m and 80m)
On my spec sheet it says tape stroage length max 40m anlong with a number that is the same on the fanuc quote. Has anyone seen this before.
I have installed all the parts (ADD MEM card and chips) and still only have 410 pages of memory.I can see jumpers on the mother board can this be possible they need moving.
http://i41.photobucket.com/albums/e2...4/fanuc10m.jpg
http://i41.photobucket.com/albums/e2.../fanuc10m1.jpg
Thanks guys
Mike Roy
Has anyone got a fanuc 10m, if you do how many pages and files of memory you have.
I have 410 pages and 50 files now, would like to know if you guys have more then this.
thanks mike roy
Check this site to see if you can find help: http://www.memex.ca/support/index.html
They offer mem-upgrades and you can download the installation guides for them. You might find what your looking for.
Good Luck,
JR Walcott
none of you guys have a fanuc 10m!!!!!!!!
Just want to know how many pages of memory you have.
It will help me, I don't know if I have the max. at 410 pages
I have come to find out that 410 pages of memory is the max. for this control(fanuc 10m modal A)I started out with 195 pages of mem. if any of you guys want to increase the mem. on their control email me at mroy7@cogeco.ca I can help.
I will also have the tape mode enabled vary soon and will give an update for that.
Mike Roy
1 page = 78 characters
78 x 410 = 31980 characters
31980 = almost 32K
I need Fanuc 10T's 9000 series parameters for a Miyano make BNC34 machine. Can anyone help?
See PM.
thanks for the list....but i have to select the options that are applicable for my machine. And then I have to convert the binary into hex code. Can you help converting the same..?
There should be plenty of instruction using Google, or use an engineering calculator to convert, just take four bits at a time in Binary and convert to Hex 0 to F,
Or you could post the particular word you want converted here.
I could manage the conversion, thanks!
does anybody have fanuc 10m parameters list? thanks
PM me your e-mail address and i can help you, i have what you need.
Mike
I need FANUC 11M/11T DI/DO connector signals. Thank
