Assuming this is a KURAKI.
The "Twin Arm" is the tool changing arm.
You should look up "EX056" in the error codes in the back of your manual for specifics.
Possibly your tool changing arm is out of position or you have a faulty limit switch, hydraulic solenoid, or your hydraulic pressure is low.
