LSI Explanation
Results 1 to 5 of 5
Thread: LSI Explanation
    Sep 2010
    United Kingdom
    Default LSI Explanation
    Hi all,
    Can anyone explain what LSI stands for and what its function is within the FANUC control?
    Dec 2003
    It usually refers to the IC technology used, LSI= Large Scale Integration.
    IOW multi pin DSP or CPU type IC's used.
    In the early days multiple IC's were used to perform simple processes.
    Sep 2010
    United Kingdom
    Thanks Al.
    So any LSI alarms on the newer i Series controls refers to issues in the relative circuit board? Such as a 749 S-SPINDLE LSI ERROR refers to a problem with a circuit board within the amplifier...
    Dec 2003
    I could not find that particular LSI fault in the manual, but from the other LSI descriptions it almost points to a memory problem of some kind?
    I see LSI overload when tapping for instance?
    Gold Member fordav11's Avatar
    Aug 2011
    Fordaville
    an error like '749 - S-SPINDLE LSI ERROR' would suggest first a faulty serial communication cable between main board and serial spindle amp module. If not then a board fault in the serial spindle amp module.
    http://www.cncalarms.com/fanuc/fanuc...ndle-lsi-error
    check/change the cable first, it's cheaper
LSI Explanation
LSI Explanation
