Need Help! Activate G54-G59 on Fanuc 21i-TA
Results 1 to 11 of 11
Thread: Activate G54-G59 on Fanuc 21i-TA
    Jul 2012
    Brazil
    Question Activate G54-G59 on Fanuc 21i-TA
    Hello, I have a cnc ROMI, with the controller Fanuc 21i-TA, and the manual says it has a 'Work' page, where is the G54, G55, etc, but when I press Offset, appears only 'Work Shift' softkey, and where it was to have the 'Work' is empty, someone could tell me how to activate this page? I work with pieces that makes in two phases in same jaw, so it's very complicated to use two tool offset for each tool, I would use the G54 and G55.
    Thanks.
    Jan 2011
    PM sent.
    Oct 2010
    spain
    If you go onto the offsett page and press the softkey at the right of the screen, It should bring up other options. It´s been a while since i used one but i ithink it is around there somewhere or if not when you go onto the workshift page press the softkey on the right of the screen and see what options come up I use a fanuc O1T now mostly as well as okuma and when i press work it comes up straight away.
    Jul 2012
    Brazil
    I tried this, but dont have the Work page, i heard its an optional...
    Thanks anyways
    Gold Member fordav11's Avatar
    Aug 2011
    Fordaville
    yes, G54-G59 is an option, very easily enabled with the correct info.... which of course can't be posted here publicly
    Jan 2014
    Default Re: Activate G54-G59 on Fanuc 21i-TA
    Hey guys, could someone please pm me how to activate this option [that was purchased with the machine] It's a Hardinge Cobra42 with the Fanuc 21-T control. Tired of reseting all of tools for any new z work piece offset. Thanks in advance
  7. #7
    Hi all,
    I'm in a bind. My Okuma Howa Act-4 has a gremlin and is down. I need to finish a sizzling hot job and am switching to
    another lathe now and of course it doesn't have the g54-g59 activated. Could someone please share how to activate that
    option? Many thanks in advance.
    -Chris
  8. #8
    Apr 2009
    That is a Fanuc option. I can send the info by private message.
  9. #9
    Registered HatfieldInd's Avatar
    May 2005
    I have a '97 Clausing Storm 110 and need to activate G54 as well. Same parameter changes, I assume? Fanuc 21i-T controller
  10. #10
    Feb 2018
    United Kingdom
    Could you pm me the info please?
    - - - Updated - - -
    could you pm me the info please??
    Thank you
  11. #11
    Member nate13's Avatar
    Oct 2020
    I’m having the same issue with the same machine, could some one PM me the info please,
