Need Help! transferring multiple programs from fanuc oi td to flash card
Results 1 to 11 of 11
Thread: transferring multiple programs from fanuc oi td to flash card
    May 2012
    India
    Default transferring multiple programs from fanuc oi td to flash card
    Hi!!!! I have a fanuc Oi-td controller, i want to take full backup of all the programs on the controller to my flash card. Can any one tell me how to transfer multiple files from the controller to flash card in one go. I tried using (edit,o-9999,f output) but it didnt work.
    Member dcoupar's Avatar
    Mar 2003
    Quote Originally Posted by vai_sa View Post
    You need to type -9999 then [O SET]. If you don't specify an [F NAME] the file on the card will be named ALL-PROG.TXT
    Attached Thumbnails Attached Thumbnails transferring multiple programs from fanuc oi td to flash card-0i-d-output-table-jpg
    May 2012
    India
    Smile
    thanx!!!!
    May 2012
    India
    Smile It works!!!!!!!!!!!!!!
    thanx!!!!
    Aug 2011
    CANADA
    I would like to have all the programs in individual files instead of one ALL-PROGRAM.TXT file. If we download from Okuma controls using *.* all the programs are downloaded in separate files which makes it lot easier to edit or archive. Is there any parameter to change this?
    thanks.
    Mar 2003
    Quote Originally Posted by arwinder View Post
    thanks.
    Not that I've found.
  7. #7
    Feb 2016
    United Kingdom
    Default Re: transferring multiple programs from fanuc oi td to flash card
    I have raised this with Fanuc Service recently (2015) this question ... it would seem using any of Guide I or Fanuc side options ...batch saving programs as individual files,cannot be achieved using any I/O device.
    Q: My question to Fanuc Service UK....
    "I have a fanuc Oi-td controller, i want to take full backup of all the programs on the controller to my flash card. Can any one tell me how to transfer multiple files from the controller to flash card in one go. I tried using (edit,o-9999,f output) but it didn't work."
    A: The reply from Fanuc Service UK was .....
    "Sorry but what you are asking is not possible on the FANUC control.
    You must either output all programs individually or output as 1 file and then edit off-line."
  8. #8
    Feb 2006
    india
    Dcoupar already said that.
  9. #9
    Jul 2010
    South Africa
    there is only one option, make a "memory dump" with O-9999,
    acquier a pc application with a file-split function to extract each individual file and save with its own number, (this is what you are after.)
    SDComms, i use this software which have specific function and it does work, visit SDComms CNC Communication Software
    regards
  10. #10
    meghshar's Avatar
    Dec 2019
    Hello all, new and learning programming. Can someone please help me on backing up Fanuc programs all at once in individual files? I tried O-9999 but it saves as ALLPROG.txt and I need individual program backup for easy access.
    Not sure if there's any specific format I can insert to get it worked. Please helpppp
  11. #11
    I use this one to split out the individual programs. It is open source and it's really short. You can easily read the whole thing quickly. It has no external dependencies. It's 100% C#.
    https://github.com/A9G-Data-Droid/Sp...rogram-Backup/
  12. #12
    Dec 2012
    The Netherlands
    Buy yourself FANUC's ---- Program Transfer Tool, .... it's only €20,- in Europe, thats $24,- all you need is a good Ethernet connection.
    You can Upload or Download multiple files, Drag&Drop, we have the v.15 version which can handle BIN-files to create large files, the program to create these files is also €20,- but only available for the 0i-D and standard for the 0i-F series, you can create NC-programs up to 2Gb.
    Check FANUC's YT-channel
