Dear all:
have any one know this option1 card use for ?
A16B-1210-0350 at fanuc system 10M
please help..
thanks
Dear all:
i have problem for the function af A16B-1210-0350 at Fanuc Option card..
i don't know what use for..
its have communication port out..
its like for DNC ?
Dear all:
please help..
thanks
A quick Google reveals it's an RS422 board.
It is high speed skip and RS232/RS422 with buffer.
"It is high speed skip and RS232/RS422 with buffer.
Al."
Dear Al The Man:
Thanks for your reply...
can i use it as like remote buffer at system 6 ?
select at Tape Mode.?
also..
do you have the wiring connection for this card ?
from PC to NC..
thanks
Will check tomorrow and get back.
Dear Al The Man:
BTW..
Do you have the Macro program for the tools Change ?
this Machine is "DAHLIH" Model DL-MCV610
System 10M
I don't have the Macro's
the conn are CA8 and CD2
Thanks..
but can its use as like remote buffer ??
because this machine just have small memory..
You should be able to, I have never used that function, it has to be enabled in the 9000 options.
I've got several of those "Option 1" cards in my workshop if anyone needs one. It plugs into the Fanuc 10, and has circuits for an additional serial port and for the high-speed skip signals. It can be used for either RS232 or RS422 signals. We used them for probe installations years ago, and we got stuck with a few extra boards.
If the serial port on your main PCB is blown, you can plug in the option 1 card (and set an option parameter), then use the additional serial port. If you have a serial port on the pendant also, then you could have up to 3 serial ports on the 10.
With the "Settings/Handy" page, you can set the "Input device" to be one serial port, and the "Output device" can be the other (option 1 card) port. Years ago, we cooked up software for a PC that would "Drive" the CNC with one DNC port and pull out "DPRNT" data with the other port. The software for digitizing a 3D surface could then be all coded into the PC, bypassing the need to load huge macros into the CNC. It worked great back then, but it's obsolete now.
Dan Would it work on the 10T?
Hi, I just want to announce that we have a new forum called Dahlih during Metalworking Machines. Why not put all the issues around Dahlih where to come.
welcome / cnc_swe
Hello Dan
We are a small workshop in Turkey.We have a Mori Seiki Mv-55 / Fanuc 10MA machine.
There is a wrong our mainboard.We can deliver a program from cnc but we cant send a program to cnc.
We bought a A16B-1210-0350 option 1 card and made the CD2 cable connection according to RS232 but it did not work.
How to set 9000 and other parameters.
Thank you.
Send me a PM with email address if you need the Fanuc 10 RS232 manual.
Hello Al_The_Man, I tried to send a PM but i looks like your inbox is full. Could you please contact us via tacarboat@tacarboat.com. Thank you.
Emptied!
Will send email.
