Fanuc 6M parameters
Results 1 to 10 of 10
Thread: Fanuc 6M parameters
    Aug 2005
    pakistan
    Default Fanuc 6M parameters
    Hi all;
    We bought a 2nd hand Amada punching with Fanuc 6M controller.
    HOW CAN WE GET,SAVE,EDIT THE MACHINE PARAMETERS?
    We do not have any manual but we know the machine parameters
    are very important and we should have a back-up copy of it.please help.
    Thank you in advance.
    S.Bahmanpour(Mr)
    Dec 2003
    Ready whatever type of upload/download device you have and set the output type to EIA (ASCII) select MODE SELECT switch to EDIT select address PRM input -9999 and push PUNCH button or whatever the button you have for output.
    The list of parameters for 0000 to 0004 are the options and should be recorded by taking them off the Parameter screen.
    They can be re-loaded by hand or by READ in. the small toggle switch on the bottom left of the main circuit board has to be in write posn. select the addrss PRM, input number -9999 via DATA key push the READ button, set read toggle switch on Mainboard back to original position.
    Registered karolg's Avatar
    May 2007
    Israel
    Hi Al,
    Any idea where I can find the Mazak micro turn fith Fanuc 5t parameters?
    Tnx
    KG
    Dec 2003
    I don't have any 5t parameters, you could try the CNC forum at http://www.cnczone.com
    Someone there may have the same machine.
    Mar 2010
    INDIA
    dear,
    Two years back, wepurchased used kitamura mycenter-2 VMC. with fanuc-6M control
    since we are facing problem after circular interpolations. ie., ovality by 0.3mm.please help me to overcome from this. Please send the PARAMETERS Also.
    paresh j
    May 2007
    south korea
    Hi Paresh,
    You can adjust by potentiometer on servo amplifier.
    Refer attached file please.
    Good luck!
    Attached Thumbnails Attached Thumbnails Fanuc 6M parameters-file0145-jpg   Fanuc 6M parameters-file0146-jpg
  7. #7
    Mar 2005
    I have an anciemt Amada Pega with the FANUC control. I will see if I still have its parameters.
    I remember that the Amada sales guy came out and got it set up..
    Greg
  8. #8
    Aug 2011
    UK
    Default Re: Fanuc 6M parameters
    Quote Originally Posted by Al_The_Man View Post
    Hi just wondering, this punches out all of our parameters up to line N0179 that's around page 9, there seems to be a lot more lines it does not take, Parameter seems to be 24 pages long and has some number going up to N4000.
    Is this correct it only take the first 179 lines. Control is a fanuc 6m
    Macca
  9. #9
    Dec 2003
    It has been 20yrs since I worked on a 6M.
    That is all I have or can remember.
    Mar 2017
    If you have RS232 communication, you set that up through 340 341 and 310~320ish right
    if it is bombing out early I would suspect a communication problem
    It wont punch timers keep relays and pc parameters.
    pS , photograph every page. more data never hurts
Fanuc 6M parameters
Fanuc 6M parameters
