hello less
i am stuck with my spindle please do some thing(alos i check that the display of the numbers on spindle motor pcb is not on(a little lcd fitted on spindle servpo pcb ) >>>>>?????
THANKS
(Regarding the ticking noise, I think what you are hearing is the guard switch solenoid.
I would remove the guard switch lid and check the the linkage inside is working correctly, sometimes a small pin in the linkage dropping out can cause problems with spindle starting)please can u explain me this note regarding spindle
LOOKING TO YOU
ASIF[/QUOTE]
