Dear All
kindly help me out in the grooving cycle programming with g75 with detailed explanation
i want to machine a groove of
width 8mm
distance from face of the job 16mm
groove radial depth 1.75mm
insert width 3mm
system fanuc oi mate
kindly reply asap
rgds
Girish
OD is also needed.
Say, it is 20 mm dia.
Use the lower left corner of the insert as the reference point of the tool.
G00 X22 Z1;
Z-19;
G01 X20.5 F10;
G75 R.2; (radial retraction in mm after each peck)
G75 X18.25 Z-24 P1000 Q2500 F10;
(X18.25 Z-24) is the lower left corner of the groove,
Peck length is 1 mm,
Lateral shift is 2.5 mm,
Feed is 10 mm/min (with G98).
If you are serious about CNC programming, you must have a personal copy of a programming book. You will find many answers there.
Edit: Replace X18.25 by X16.5 for 1.75 mm depth
