clap clap clap, you are a genius, you are the messi of the cnc. thank you from Argentina!!!
Need your help:
We have GOODWAY GLS 200 CNC machine and want to adjust the zero point the turret .... but the problem is when we try changing relay No. 7 bit No. 5 to 1 (Turret JOG Mode) a message appear "write protected" and the value of the bit never changes to 1. can anyone help me with this problem...thanks
A big thank you from Russia!!!!
thank you Mr zavateandu for your replay ... I changed the PWE to 1 and it worked with me
if the turret is not rotating it means that or is not unclamped by hydraulic cilinder or is unclamp but the sensor that should see it ,is not working.
check in diagnose the input for the sensor if it is going from 0 to 1,if not,try to adjust the sensor or replace it if is broken.
the turret will rotate only if the cnc see the senor for unclamp in 1 position ,otherwise will not rotate.
Hi all.
I have a goodway gcl-2b cnc machine.
The reference position changed and I can’t get it to go back and stay. If I move it with the handle back it goes but once I press Referance position it’s goes right to the turret
how to fix this alarm sir
Please send me the procedure i have the same problem on my cnc lathe goodway
Can you send me the procedure
