Help needed to transfer gcode files from Pc to 8055tc
Results 1 to 5 of 5
Thread: Help needed to transfer gcode files from Pc to 8055tc
    Member jubee's Avatar
    Mar 2004
    Brisbane
    Default Help needed to transfer gcode files from Pc to 8055tc
    Hi All,
    After some advise on how to send files from pc to Fagor 8055 tc Lathe controller.(older version earlier 2000 model)
    Cant see anything in the manuals , but i see a serial port on the side so I'm assuming i can.
    here is a screen shot of the front panel Help needed to transfer gcode files from Pc to 8055tc-capture-jpg
    Any ideas ???
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Help needed to transfer gcode files from Pc to 8055tc
    ...this may help you. I see a link for the cable wiring and some free software here>https://atrump.com/images/tech_suppo...munication.pdf
    There is also Putty you can use to download. > https://www.putty.org/
    Good luck hunting,
    DJ
    Mar 2004
    Brisbane
    Smile Re: Help needed to transfer gcode files from Pc to 8055tc
    Thanks for that will check it out
    Mar 2004
    Brisbane
    Had a look , i cant get to the screen that says load. Not working for me.
    Ive checked manuals and cant see anything
    Surely there's a way to send a gcode file to the machine.
    Mar 2004
    Brisbane
    further to my last .........................Shift key then ESC works , happy days
    i was holding both keys down together
