Need Help! Fagor 800 T Error 99 M table
Results 1 to 6 of 6
Thread: Fagor 800 T Error 99 M table
    Member Pokeman1's Avatar
    Jan 2022
    Default Fagor 800 T Error 99 M table
    Fagor 800T was working, then battery flat, now replaced, now won't move.
    Get error 99 Parity error M table..??
    Think that means codes missing or corrupted.
    I can display codes but have nothing to compare them to. ??
    I have read through manuals and this and other forums.....difficult to get details about actual codes.
    In the manual it says M41 is 0100 0001 which seems simple is is 41 in BCD.
    But then on another page it gives other codes for M41 with a long string of 1s and 0s for activating and deactivating the bits...
    I find it difficult to understand this coding or conversion.
    Is the user meant to build the M table from working out the codes manually and entering or is it possible to get a generic list in a file to download and only edit the ones that need changed.
    Is there a common or general list somewhere that would get the machine going again...???
    Ned1993's Avatar
    Sep 2022
    Default Re: Fagor 800 T Error 99 M table
    We have a Fagor 800m with the parameters backed up in photos. I'm not sure how useful they will be to you but If you need them please let me know. and Yes i know i'm replying 9 months after your post
    Regards, Ned
    Member Jelcke's Avatar
    Sep 2022
    Hello,I have a similar problem with the Favor controller and would very much like to receive the screens with the settings.thanks !
    Best regards, Jelcke
    mail@jelcke.nl
    Sep 2022
    Hello Ned,
    I have the same fagor controller with lost settings.
    Could you please post or mail the photos?
    Thanks,
    Jelcke mail@jelcke.nl
    Sep 2009
    India
    I have an 8025T where I am having the same error- Error 99 Parity Ms. Is this relating to the PLC? Do we need to restore it from the EEPROM? I am unable to find much information on this unfortunately
    Any help on how to resolve this issue would be most appreciated.
    Best regards
    Jaideep
    Member radeksr2's Avatar
    Dec 2022
    Quote Originally Posted by Ned1993 View Post
    Regards, Ned
    Could I also please email radeksr2@gmail.com thank you
