up on that subject as i'm still stuck :-(
Hello everyone,
i used to use this fagor 8035 with a win2000 pc and now it's time to put a new computer on it.
I wanted to use the ethernet port with a crossed ethernet wire but i cannot find where to set it up in the command.
It seems that the parameters are not there. is there any way to "activate" this functionnality?
Is it restricted on several models ?
i only see the rs232 settings in the menu.
Thank you for helping me as i'm stuck on a stupid thing like that.
Fred
The Ethernet is a payed option in that cnc model.
To check if it is active, go to main menu-> + -> diagnosis -> configuration -> software configuration
It should display a list with active options.
If you don’t see Ethernet in that list it is not active.
To activate you can contact the global sales network of fagor automation www.fagorautomation.com
If it is there you should go to machine parameter and setup the IP address.
