Hello. I was hoping to get some help correcting spindle speeds on my 8050.
Theoretical RPM and actual are not matching.
I wasn't sure what parameter to adjust to fix this.
Machine has a geared head.
1st gear only runs at 80 rpm
2nd gear runs at 300
3rd runs at 800
Override + doesn't work
override - does work some
Encoder Parameter is set correct and encoder seems to be working properly.
Machine also does not throw any error codes.
Any help would be greatly appreciated. Thank you.
