- Need Help!- FAGOR 8037 - How do you set the Soft-Limit on "Y" Axis.
Howdy,
I'm trying to set the soft-limit on the "Y" axis to prevent accidentally cutting into the spoil board.
Any help is appreciated, Thank you
Re: FAGOR 8037 - How do you set the Soft-Limit on "Y" Axis.
Hi ,
To Set The Y axis Soft-limit , you need to access Axis Parameter from the CNC and goto Y axis and replace the parameter for the same . You can refer the manuals which can be download from //FAGORAUTOMATIOn// website
Please excuse my grammar & typos
Avinash .
For in-depth support feel to contact .
Thank you, I will try today see if it works.
- You may not post replies
- You may not edit your posts
Forum Rules
