- 8055i Questions - Used Lathe
Hello and thanks in advance.
I just got this used lathe and finally got it hooked up to electrical service and when I turn the machine on all is fine, then I can usually move the table for 10-20 seconds then I get errors. Normally E605 or E203.
I have to questions.
1. How do I backup parameters for the machine so I do not loose them?
2. Any ideas how to troubleshoot or what is causing the errors?
- You may not post replies
- You may not edit your posts
Forum Rules
