Did you get to the bottom of this? I'm stuck in the same situation. The manual doesn't even seem to have a chapter on error codes.
Needing some assistance in figuring out this z-axis servo error code 1211,
I've Googled and found a couple of things to try like checking the wiring and connections with no luck,
Any help would be appreciated,
Thanks,
