- Black screen on 8040T
I contact you because I have a problem with the realmeca T2 Universal Plus lathe.
When I turn the power on, the screen turns off (black screen)after a few seconds and nothing works (no key beep or power on possible).
Sometimes it works after stopping and restarting it many times.
When it starts correctly, I could see that all voltages are ok (including the battery).
I tried to push sockets behind the screen but it doesn't change anything and the 4 fuses in the rear cabinet are good.
Do you have suggestions to try?
Thank you in advance.
- You may not post replies
- You may not edit your posts
Forum Rules
