Need Help! PLC: 0030 (TOOL COUNTER ERROR), FAGOR 8055i can't reset
Results 1 to 6 of 6
Thread: PLC: 0030 (TOOL COUNTER ERROR), FAGOR 8055i can't reset
    Sep 2009
    Macedonia
    Default PLC: 0030 (TOOL COUNTER ERROR), FAGOR 8055i can't reset
    we just bought a MICROCUT machine RIC-MC 600L with fagor 8055i control, and we got this two alarms
    CNC: 2000 External emergency activated
    we think that somehow we manage to make the tool counter to loos the track of the numbers
    also we found this explanation in one of the MICROCUT manuals:
    CAUSE : TOOL COUNTER SENSOR TO COUNT LOSE OR ERROR
    SOLUTION :1.CHECK THE TOOL COUNTER AND HOME SENSOR IS CLEAR
    2.CHECK TOOL COUNTER AND HOME SENSOR IS NORMAL
    3. RESTART CNC AND EXECUTE M59 T1 SEARCH
    we check all the sensors they are ok, all that is left is to execute M59 T1 , but I cant do that because
    the machine is in emergency state and I cant input that so I can execute.
    Does someone knows how to enter the ATC SERVICE MODE for umbrella type ATC?????
    I think that only in that mode I can execute M59 T1 and make the tool counter to find tool No:1 position
    Please advise
    regards to all
    Mar 2008
    Argentina
    Default Re: PLC: 0030 (TOOL COUNTER ERROR), FAGOR 8055i can't reset
    Did you solve the problem??
    Carlos Cabrera
    Sep 2009
    Macedonia
    yes, the machine is working just fine.
    fazilb's Avatar
    Apr 2017
    MALTEPE
    Hello Vladimir,
    Could you please tell us how to fix your problem. Because we are having same issue and do not know how to fix it? Please support us
    fazilb's Avatar
    Apr 2017
    MALTEPE
    Hello Vladimir,
    Hello Vladimir,
    Could you please tell us how to fix your problem. Because we are having same issue and do not know how to fix it? Please help me thanks
