Fagor 8055t lathe / Mastercam post
Results 1 to 6 of 6
Thread: Fagor 8055t lathe / Mastercam post
    Feb 2005
    New Zealand
    Default Fagor 8055t lathe / Mastercam post
    Can anyone out there help me out with either a copy of a mastercam post that is capable of canned drill cycles for a Fagor 8055T lathe controller or possibly help me out with modifying the one I have. I have managed to modify the post to do everything except output the "Drill Point" Z position. Does anyone know how to source this in a mastercam post.
    Cheers
    Mark
    Mar 2003
    Setup your drill. In parameters select the drill point button, select point entry. If no point or line exists make one. Be careful with using abs and inc. steveo
    Jan 2011
    portugal
    Quote Originally Posted by MBFisher View Post
    Cheers
    Mark
    You have the mastercam post processor for fagor 8055t can you help me?
    Registered bthomps5's Avatar
    Jan 2005
    Default i have talked to dealer
    i need post for my 8055t lathe control
    dealer sent me my post but it is all screwed up
    we have sent emails back and forth and still nothing even looks simular
    http://www.landwfab.com
    Member firekoe's Avatar
    Dec 2009
    canada
    have u had any luck with getting a post to work?? i just got a fagor 8055 and was woundering if you would be willing to send me a copy of the mastercam post?
    Member Altool's Avatar
    Oct 2019
    Default Re: Fagor 8055t lathe / Mastercam post
    In search of Fagor controls for lathe .PIT for Mastercam 2021. any help would be greatly appreciated .
