- Need help for my g code generation issue
I am using Solidworks cam 2018. The workpiece I wanted to create have 4 arcs at the side, which make the post-processor generated G02 and G03 which give it a round corner, but what I want is a sharp corner. Can anyone help? I tried to edit the definition of my milling operation many times still cannot be solved.
Re: Need help for my g code generation issue
....try using G09 (Exact Stop) is non modal. or G61 for modal on Fanuc systems
https://en.wikipedia.org/wiki/G-code
- You may not post replies
- You may not edit your posts
Forum Rules
