need help with photoelectric sensor
Results 1 to 1 of 1
Thread: need help with photoelectric sensor
    Default need help with photoelectric sensor
    hi guys this is my first post about cnc im new to this
    im looking for some help with an issue im have with wiring up a indexing sensor
    i have converted my manual lathe to cnc which ive got working fine with mach3
    ie: steeper motors
    im trying to wire up a spindle index sensor up ive made the pick up disc with the correct slot on i and mounted it to the lathe shaft
    im struggling to get the sensor to ive got the led light to flash when some thing is passed through
    it but i get nothing on mach3 screen on index pulse light
    the board is wired up to a 24v power supply and a separate one for the motor drivers
    also have a separate 5v supply for the board to work
    i have included a pic ok the sensor im trying to wire up and also a pic of the board im using
    this is the link to the data for the sensor omron ee-sx672a
    https://www.ia.omron.com/product/item/2225/
    any help will be greatly appreciated
    thanks ian
    Attached Thumbnails Attached Thumbnails need help with photoelectric sensor-img_0317-jpg   need help with photoelectric sensor-img_0318-jpg
