Post procesor for my milling machine
Results 1 to 2 of 2
Thread: Post procesor for my milling machine
    Oct 2014
    Default Post procesor for my milling machine
    Hi , I built my own 4 axis dental milling machine. It works under Mach 3 so and I need to adapt the 2015 Delcam Dentmill CAM software for my machine kinematics. Is it possible ? All I know is about to create post procesor .
    Gold Member
    Apr 2004
    Oakland CA USA
    Default Re: Post procesor for my milling machine
    If your milling machine only has four axes, the kinematics aren't too complicated. Set up X, Y, and Z as linear Cartesian axes, and A as a rotary axis parallel to X calibrated in degrees. You can do all that in Mach3. If you know how to create the post-processor for that CAM program, it should just work. If not, you should be able to get help from DelCAM, or Autodesk, which acquired them.
    Is that a picture of your "Babin" machine? It looks more like a lathe than a mill...
    Andrew Werby
    Website
