- EZ Router Control Board Problem
Hello, along with a technician from Lone Star Cutting Solutions (EZ Router), I found out that my main control board is bad. X axis has failed on the main board. Question; since the board that I have is pretty much obsolete, what/where would be a good place to send the board out for a possible repair? I have heard that ACS in Hickory NC is a good start. The machine is a 5X5 foot table, with a parallel port control board running Mach3. Any suggestions? Thanks all!
- You may not post replies
- You may not edit your posts
Forum Rules
