Need Help! IC DSP CHIP. Mfg Part: TMS320C32PCM60
Results 1 to 4 of 4
Thread: IC DSP CHIP. Mfg Part: TMS320C32PCM60
    Jan 2017
    South Africa
    Default IC DSP CHIP. Mfg Part: TMS320C32PCM60
    Hi there, I am Ruthain here,
    I have Anilam CNC mill that now pops up on the screen of the machine at the boot up an error message saying:
    "CCU DL TIMEOUT.
    ERROR LOADING CCU FIRMWARE!!! C\:>P6M"
    Unfortunately, the manufacturer of the machine doesn't do the support anymore but they suggested I look at the DSP board of my machine. So, my technician suggested replacing the chip could be a better option.
    The firmware details of my controller are:
    "Anilam 6000M CNC Software
    Version 3.05A
    CCU firmware version 246280.10"
    Does perhaps anyone here knows how o go about solving this issue please?
    Thank you
    Best regards
    Ruthain
    Member machinehop5's Avatar
    Aug 2009
    Default Re: IC DSP CHIP. Mfg Part: TMS320C32PCM60
    ...does this Anilam CNC have a HDD? Does it have a CMOS Battery that needs replaced or has been replaced? ..... If, so your BIOS settings would need to be reset.
    DJ
    Jan 2017
    South Africa
    Hi DJ, Yes, My CNC has HDD and a CMOS Battery which i replaced already and i tried the BIOS settings but i only do some minors reset. Yet it still gives me the same error message over and over. Do you mind perhaps help me out with the proper way of resetting the BIOS maybe?
    Thank you in advance
    Jan 2017
    South Africa
    I even tried replacing the HDD by a new one yet still gives me the same error message
