Auto stop tabs don't aren't working. Z keeps going up ....Any Help?
Results 1 to 4 of 4
Thread: Auto stop tabs don't aren't working. Z keeps going up ....Any Help?
    Mar 2007
    Default Auto stop tabs don't aren't working. Z keeps going up ....Any Help?
    Hi there, sorry about the typo in the heading, I can't change it...
    I have an 1212-120 machine, and just today, the magnetic switches that stop the machine from crashing into -X and the Z stop + have seemed to have disappeared.
    They aren't "seeing" the metal tabs in other words, and the machine will keep trying to + the Z axis and it's horrible to hear. and the X will and will hit the end of the gantry, so I cant even Home the machine right now.
    Can any one think of the reason for this? Is it in the machine or in the pendant? I'm assuming the machine because the stops, I would have thought, would be cut out switches, right?
    EDIT* The little red LED on top of the Z sw/ illuminates as normal, but the Z+ will keep going instead of stopping.
    Anyway, can someone help? Anyone!
    Cheers
    Steve
    May 2012
    New Zealand
    Default Re: Auto stop tabs don't aren't working. Z keeps going up ....Any Help?
    Hi Steve,
    Just found your post, did you fix the fault? I have a Excitech 1325 with the same fault. My machine is a 2012 model. Would appreciate any feedback.
    Thanks, Mark
    Sep 2011
    surinam
    Hi, having similar problem any sugestion ...
    May 2012
    New Zealand
    Quote Originally Posted by abel2b View Post
    Hi, it was a while ago. From memory it was z axis micro switch I had to replace at the top limit. I think the machine came with a spare. Anyway the exitect technician talked me through it via what’s app
