- tos fng 63 cnc
tos fng 63 cnc
I purchage a used tos FNG 63 cnc milling machinewith Heidehain Tnc360 controller . All the machien parameters
Mp are set default to 0.I m chaning some parameters manually but after power suthdown all this data is not saved.Bateries in th plc are charged. seems that machine needs program download. Due that i didnt find a back up file to downaload
is there somebody guide me how i can start up this machine?
Thank you in advance,
Re: tos fng 63 cnc
hi teokar,
check the battery holder connections i have had the same issue a few times and had to replace the battery holder. cant help with machine parameter unfortunately.
- tos fng 63 cnc
- You may not post replies
- You may not edit your posts
Forum Rules
