- Enshu S400 ENAC programming problem
Hello all,
I've a problem on a Enshu S-400 Enac CNC machine with Jaskawa JZNC-IRK31M-131J00 control. I need to reprogram this machine but I don't know how to set the circular switch on the FC200 board to allow the reprogramming from the FC903 board by RS232 interface.
Therefore the questions are:
1) Could anybody explain to me the different circular switch positions on the FC200 board ? Which is the correct position to allow reprogramming ? I'm unable to find a manual on the web.
2) Since it's my first time ever that I have to reprogram a CNC machine, could anybody explain to me how to do it (at least the main passages) ? I will use Cimco Edit 8 with the original CNC programs.
3) Which is the pin diagram for the RS232 interface for the file transfer between the CNC and the computer ?
I've attached some photos. Don't look the japanese write, now it's in english.
Thanks in advance
https://i.postimg.cc/85dTWcQ6/1.jpg
https://i.postimg.cc/MGyC3LPk/2.jpg
- You may not post replies
- You may not edit your posts
Forum Rules
