Lathe - Carbon-Carbon Brake Disc Machining, Any ideas?
Results 1 to 3 of 3
Thread: Lathe - Carbon-Carbon Brake Disc Machining, Any ideas?
    Mar 2018
    United Kingdom
    Question Lathe - Carbon-Carbon Brake Disc Machining, Any ideas?
    Hello All,
    I on the hunt for any information regarding machining Carbon-Carbon brake discs, used primarily in Motorsport.
    If anyone has done this before, probably a little niche, any info regarding Insert coatings and geometry also feeds and speeds - were talking CNC turning here.
    Thanks for any help in advance.
    Sam
    Production Engineer
    CNC Programmer, Setter, Operator
    Mar 2018
    Finland
    Default Re: Lathe - Carbon-Carbon Brake Disc Machining, Any ideas?
    Carbon-Carbon composite is the toughest, most heat resistant material we have on this planet and off... This is the stuff they put on the leading edges of the hypersonic SCRAM-jet.
    Are you sure you have to put it in a lathe? Might be a job for EDM.
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by DrNos View Post
    A EDM would not be suitable to machine this material, it can be Milled Drilled or Turned without to many problems
    Mactec54
