epoxy granite vs natural granite
Results 1 to 4 of 4
Thread: epoxy granite vs natural granite
    Jul 2014
    Default epoxy granite vs natural granite
    Hello
    What is better for vibration damping stiffness accuracy etc the natural granite or epoxy granite ?
    Because for me natural granite costs much less than epoxy granite...
    For a cnc router 2m X 1.5m table sides and grantry is enough 12cm think granite or must go with 16cm thickness ?
    I will use hgr20 rails with 1605 ballscrews with rotating nut not rotating ballscrew.
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: epoxy granite vs natural granite
    Hi MR - If you have access to natural granite and can work natural granite then that's the way to go. Its stiffer and more stable then EG. For that size machine I think you should use 25 or 30mm rails not 20mm. Peter
    Jul 2014
    thank you.
    What do you think about thickness of granite for this size machine? 12cm is enough or needed more for example 16cm ?
    Jul 2018
    dum dum
    Hi Mrsa - 120mm of granite is a very stiff chunk of material. For a router I'd expect it to be fine maybe even a bit over what's needed. Will be a heavy chunk of material!! Peter
    Banned
    Oct 2020
    I completely agree with what you talked on here, but I just felt the need to share from my personal experience. I was so close to not going with natural granite for silly reasons, that I'm so glad I changed my mind at the last minute. I think it was after I read this article http://countertopshq.com/dallas-white-granite/ (maybe it can help you as well) and I actually continued on collaborating with the company that published the article because I really liked the pictures in there, it was exactly how I wanted my kitchen to look. It seemed like I could look at the finished product in my house because mine is also a thin and long space that needed something to make it seem more luxorious.
