New Machine Build Bumblebee 300x300x150mm - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 17 of 17
Thread: Bumblebee 300x300x150mm
  1. #13
    Apr 2017
    Ukraine
    Default Re: Bumblebee 300x300x150mm
    Thank you. This machine was made as hobby, for my shop. i was made it about 6 month with including time for study and experiments with best mix for me. And this one compare all my expectations - really rigid frame and heavy. Base net weight about 80 kg gantry about 60. i was instal stepper temporary but now installed servos. i want do replace all aluminum pats for cast iron and steel and install more powerful spindle. Maximum feed is 7200 mm/min (limited by soft) no need higher. acceleration for tests 5m/s2, but this acceleration made scary cabinet shaking so i decrease it for 2.5m/s2. there is some videos Thank you
  2. #14
    Mar 2017
    Quote Originally Posted by smlua View Post
    Why did you decide to replace the steppers with servos?
  3. #15
    Apr 2017
    Ukraine
    Hello.
  4. #16
    Activation process peteeng's Avatar
    Jul 2018
    Hi Smlua - Whats your feed and speed rates? or chipload? very nice. Peter
  5. #17
    Apr 2017
    Ukraine
    im trying to write it in description in youtube clips. Usually im trying to keep 0.06-0.08mm/t. And now all aluminum parts replaced for cast iron Bumblebee 300x300x150mm-viber-image-2019-03-06-11-03-a
    Attached Thumbnails Attached Thumbnails Bumblebee 300x300x150mm-viber-image-2019-03-06-11-03-a
