epoxy granite sliding on epoxy granite. - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: epoxy granite sliding on epoxy granite.
  1. #21
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: epoxy granite sliding on epoxy granite.
    Hi Pippin here's a good read. Peter
    Attached Files Attached Files
  2. #22
    Member deprutser's Avatar
    May 2022
    Quote Originally Posted by peteeng View Post
    Hi Britt - Search for koehler article in the forum. The concrete guys have thrown out the graded approach. A two size mix seems to result in the best packing factor. Peter
    Agreed. This guy [1] came to the conclusion 66% sand and 33% dust makes the most stiff bar. Moving to 33% stones, 33%sand and 33% dust yielded the same results.
    [1] Epoxy granite stiffness - test and results
  3. #23
    Jul 2018
    dum dum
    Hi All - Very good video. Shame he didn't use an aluminium bar as a baseline in the tests. But if we look at his chart and most laminating epoxies are 3-3.5Gpa and if his stiffness rating is based on the deflections then the EG is ~10x stiffer. ie 3.5/1.2X10= ~30Gpa which is typically what the EG guys are getting. Peter
    Attached Thumbnails Attached Thumbnails epoxy granite sliding on epoxy granite.-eg-jpg
