Epoxy-Granite machine bases (was Polymer concrete frame?) - Page 249
Page 249 of 249 FirstFirst ... 149199239246247248249
Results 4,961 to 4,976 of 4976
Thread: Epoxy-Granite machine bases (was Polymer concrete frame?)
  1. #4961
    Jan 2005
    Default Re: Epoxy-Granite machine bases (was Polymer concrete frame?)
    Quote Originally Posted by peteeng View Post
    Hi All - Here's a new test piece of Tetrium, facing threads and engraving. Because of the fibre reinforcement it didn't engrave wonderfully. Next I'm making a large chunk 300x300x40. Then some part moulds and parts... Peter
    You are having fun with this, a few years ago there was a Zone member that was casting small Z axes blocks which had an a aluminum filler which worked very well, and was strong, I don't think he used very much if any fiber as his parts machined very well
    Mactec54
  2. #4962
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi Mactec and others - I have made moulds for things using epoxy/aluminium (Aluminum) powder in the past mainly for heat transfer characteristics. It machines very well as aluminium machines well. My aim with Tetrium is to maximise its stiffness and be machinable. If the part is not to be post machined then using the Al2O3 (Alumina) is the go as it has the potential to be very stiff and easy to make. Epoxy granite using SiO2 will get to ~35GPa and using aluminium powder will get to ~20GPa. My current aim is to be equal to monolithic aluminium in stiffness.
    Tetrium uses two very high stiffness fibres (vs a particle) and one of these pulls out of the epoxy vs cuts as far as I can see under magnification. This roughens the surface. Does not affect its performance, a wipe with epoxy or paint it will fix that. The fibres parallel to the cut do cut. The next block aim is to maximise density, then the next, next block will be made to test its modulus. I have discussed testing its dampness at a Uni lab and initially they wanted $33000AUD and 60 test samples. I talked them down to a one test sample and $600.... So I'd like to know its damping factor. I'm sure "as it is" it will make very good damp parts. I want to get into the mill design asap and I need to settle on a std formula and know its stiffness to do this.
    Unfortunately I have not been able to get my resin of choice. It's a Reichhold tooling resin and it used to come into australia then they mixed Aluminium Trihydride powder with it here. I used to get pails of it without filler. They now bring it in premixed and are unwilling to bring it in unmixed. So I have to use an epoxy which is a bit thicker then the Polylite resin. I may have a look at acrylics and have been looking for a suitable phenolic for years.
    For your interest - Many things can be infused or embedded in epoxy including plastination of body parts see https://fasciaresearchsociety.org/plastination Cheers Peter
  3. #4963
    Jul 2018
    dum dum
    Obivan - These guys get good epoxy in Russia. Peter ??????? - positive couple
    https://ecovanna.ru/
  4. #4964
    Jul 2018
    dum dum
    Hi All - That Russian casting epoxy looks fantastic. Very thin and clear, no bubbles and can cast up to 100mm thick!. Which means with a filler probably no limit to part thickness. Perfect for epoxy alumina or EG. I'll send them a note and see if I can get it sent to Oz. I'm setting up a 200x200x40mm billet of Tetrium. The aim with this billet is to maximise the fibre density. So since I know the volume I shall calculate the weight of fibres required to achieve 50% volume fraction. Then I shall try to squeeze that amount into the mould. Usually with carbon fibres and glass fibres or sand this is easy. But the high stiffness fibre I have is slightly curly so does not pack well. Once I figure the max pack I shall freeze the formula and then do the mechanical testing. Then I can start designing the Mill. Keep Making - Peter
  5. #4965
    Jul 2018
    dum dum
    Hi Alll - I made a block of Tetrium yesterday 200x200x40mm thick. Turned out not as dense as I want but for now I think it's as best I can do in my garage. Also didn't get the vacuum down as far as I liked. When I tested the system I got down to 200Pa but the job only got to 1200Pa. I'll have to make make better fixtures and get a press to consolidate the dry stack better. But it's good enough for parts. This block is being sent to a friend who will make motor mounts out of it as a test. So short list is; make a metal flat mould/table with vacuum clamp and make the block for modulus testing. This block weighs 3.4kg and has a density of 2200kg/m3...By the way the fibres are black so close to what Mr Ford said, "You can have any colour you like as long as its black"...Cheers Peter
    Attached Thumbnails Attached Thumbnails Epoxy-Granite machine bases (was Polymer concrete frame?)-tetrium-block-2-1-jpg   Epoxy-Granite machine bases (was Polymer concrete frame?)-tetrium-block-2-3-jpg
  6. #4966
    Jan 2005
    What was in your complete mixture and is it cost effective I'm interested in doing some parts like this as well, I have some very good 2 stage vacuum pumps and can make any kind of molds
    Mactec54
  7. #4967
    Jul 2018
    dum dum
    Hi Martec - As I want to commercialise this product I can't say exactly yet but it's mainly a metal fibre. There are a couple of metal fibre makers in europe and I'm sure in the USA as well. If you are to make parts for yourself then look up "infusion" processes for composites. Parts for yourself would be better to use carbon fibre or glass fibre. For instance if you used a quadraxial stack of glass you will get better properties then epoxy granite and glass is easy to infuse. CF is tricky to infuse in thick sections. You can make glass blocks and post machine or make one off simple moulds from MDF or ideally aluminum for production parts. If you use a quadaxial stack of CF then you are at 65GPa which is close to aluminium. F1 teams call this black aluminium. My aim is a product that can be made in large billets and sold like metal that routers can machine easily. Slightly different objective then making parts for yourself. Sounds simple make a mould, put it under vacuum and suck some resin in but as usually easier said then done. But it all can be figured out. Regards Peter
    If I where to make parts for myself I'd do them as glass fibre stack then post machine or make a mould and infuse. Much easier. Yes Tetrium is economical compared to billet aluminium a long as I can get the volume to get the fibre at the right price. The usual commercialisation hurdle. Need volume to make it work but at start up how do you do that? Its tempting to use very low pressures but if you go really low you will pull out constituents of the resin hardener and it may not go off! So an ideal pressure is around 500-600Pa this minimises the air volume in the part, and burns off the water in the constituents. You will need a resin trap and if you do make one that has a glass or acrylic port so you can see whats going on inside. This way you can put a hardener in there under process pressure and see if its outgassing. If not all good. If its giving off vapours then increase to find out at what pressure it does not outgas, that's your bottom process pressure for that hardener.
  8. #4968
    Jul 2018
    dum dum
    Hi All- To summarise my research and practicum so far on EG:
    One off parts or small run with finish machining on routers and mills
    This means ceramics are out. So use aluminium powder, metal fibes, glass fibres or carbon fibres as all of these are readily available. If you can use vacuum infusion processes then you will achieve very low porosity and if you use the vacuum for consolidation pressure you will achieve high reinforcement volume ratios. Convert your weights to volumes as just going by weights is an unreliable process as the resins and reinforcements vary in density so weight ratios can be very different for different materials. Traditional epoxy granite can be bettered in terms of stiffness by using glass fibre and carbon fibre and they machine well on routers or mills.
    The epoxy needs to be a very thin type typically used for infusion or deep clear castings. It will be a 100% solids epoxy no solvents and it will be suitable for thick sections ie its hardener will be a slow hardener not an active hardener. This is for ceramic reinforcements as well. Suitable epoxies have been discussed in prior posts. Epoxy is used because its shrinkage is very small and it produces parts with very little internal stress ie the part will not change shape over time. Other types of resins will cause the part to change shape due to their large shrinkage values.
    Multi parts requiring a mould or parts that do not require post machining
    If you commit to a mould and you do not intend to post machine the part this is the reinforcement I would choose:
    1) Alumina Al2O3 grit 300GPa about 50%-60% packing factor ~1mm particles. Typically this is a grit blasting media available in brown or white grit. Will produce a material near stiffness of aluminium. Can be drilled with a masonry drill for instance to instal inserts.
    2) Sand or Sio2 70Gpa about 50%-60% packing factor ~1mm particles will produce a material same as traditional epoxy granite or better
    The optimal grading theory using 3 or 4 or 5 sizes of particles has been thrown out. This is a hangover from concrete that uses large rocks that have large gaps. You may get small pockets of good interspersion but generally its all compromised by viscosity and improper settling.
    Use a single small diameter grit and you will get a better pack and a better result. Use a very thin epoxy. Traditional hand layup epoxies are too thick to penetrate, too thick to flow, too thick to degas, too thick to mix & did I say too thick?just too thick! for many reasons...
    Using moulds
    Moulds require a space to be packed and this is the most difficult issue in producing moulded shapes. Therefore the particle approach is best as they pack easily and with a bit of tamping will pack even better. Long fibre or fabric cloth can be difficult or impossible to pack into certain shapes. Therefore again particles are good. Moulding using alumina for instance means you could mould in fastener threads, or thread inserts or blank bits of metal for post machining. Moulds would be net shape and you can premake the slurry and pour in or pack it dry and use vacuum to fill the part.
    Anything else I should add? Please ask. Peter
  9. #4969
    Jul 2018
    dum dum
    Hi All - I'm sending some Tetrium to a friend for making into motor mounts. I was going to wait until I had access to a power saw but decided to hacksaw it so I could get it away today. Cuts well. The cross section has been dressed with 80 grit. Now to make a big table so I can make slabs. Peter
    Attached Thumbnails Attached Thumbnails Epoxy-Granite machine bases (was Polymer concrete frame?)-cut-jpg   Epoxy-Granite machine bases (was Polymer concrete frame?)-cross-section-jpg
  10. #4970
    Mar 2008
    But has anybody tried sawdust? Aside from these guys, I mean: https://iopscience.iop.org/article/1...53-1591/ab279e
  11. #4971
    Jul 2018
    dum dum
    Hi Flick - i think everything has been tried. But sawdust is not very stiff so is just a filler does not make it any stiffer. Peter
  12. #4972
    Dec 2016
    Norway
    Very informative thread. Tons of info here and impossible to remember it all
    I have attached a datasheet for a resin/hardener combination.
    What do you think about this one for an EG cast?
    400mpas viscosity - good.
    Potlife 30min - on the shorter end of the scale, but manageable for smaller batches?
    Anything else?
    Attached Files Attached Files
  13. #4973
    Jul 2018
    dum dum
    Hi Buoyen - 400 is a bit thicker than many out there. But it will work. Look up Biresin CR83 via SIKA. 155 mpas and longer gel time. The longer gel time allows the resin to wick into corners and filler better. Peter
  14. #4974
    Dec 2016
    Norway
    Okey, great, thank you!
    I'll have a look for CR83. But I can get the BC309 local so that is easy!
  15. #4975
    Jul 2018
    dum dum
    Hi Buoyen & welcome to 2020!! - I've just read the TDS and I think you need to send a note to the supplier asking what is the maximum thickness this can be cast in. Its application is for relatively thin floor coatings and 30mins gel is quite active. So if you cast this at say 25mm thick I expect it will exotherm considerably and may burn. By burn I mean it could get hot enough to destroy itself, it turns a very ugly brown and cracks and smells and its structurally destroyed. Thick casts of the wrong resin can ignite in the right conditions as well (or wrong depending on what side of the event you are on). Epoxies are formulate for thin film curing or thick film. I think this is a thin film. Thin film assumes the substrate will absorb the exotherm and being thin film it needs lots of energy to cure (as it sheds heat to atmosphere very easily as its thin) hence the fast gel time, plus thye fabricators don;t want to hang around for hours for this to cure. The filler will absorb heat that's good. Perhaps do a trial cast at your expected thickness and mix but do it outdoors, away from any flammable stuff!! Not on the kitchen table... Peter
  16. #4976
    Dec 2016
    Norway
    Ok, thank you Peter for looking into this.
    But I guess the granite will absorb most of the heat beacuase a 8% epoxy weight it is relatively low. But I'll maka e test first.
    Also the castings I have planned will weight about 70kg and I can only mix about 5kg at a time so there will be several layers.
