- CNC beginner setting up 3040 engraver mill
Hey, so way back in 2014 I bought a 3040 CNC engraver but never managed to get it set up. It was a pretty generic Chinese 3040T-DJ model, I think this is the same one https://www.aliexpress.com/item/32320079504.html. Basically my issue at that time was a lack of a parallel port on my PC and having no 32-bit OS.
Now after many years, I am trying to get this thing started again. My requirements for the software are that it run on x64 Windows, so I think I have to go to Mach 4 for this.
I have read that I can use an ESS SmoothStepper to interface with Mach 4 on my x64 PC and get better performance than if I used the parallel port.
My question is if I need any other items to get the machine to run. I have seen mention of various breakout boards which I think control the steppers, but do I need these or do I just plug the parallel port cable from my CNC controller box into the SmoothStepper?
As you can probably tell I am an absolute newbie with CNC so I appreciate any assistance, thanks.
Re: CNC beginner setting up 3040 engraver mill
I think it will be easy to use the UC100 USB for this cheap machine and newbie
https://www.automationtechnologiesin...ion-controller
You can use this box if you like the SmoothStepper,
https://www.automationtechnologiesin...or-mach3-mach4
Another New guy here. I have a Jing Yan Instruments CNC 3020-800W engraver/mill that seems to function OK. it has a JY5800 controller.
The controller has a parallel port AND a USB port....that suggests I can use the USB port instead of the parallel port??
Looking for software info.
Also, I'm looking for a Manual, hopefully in English, would be nice..
Not much luck getting info off the web...
Thanks DW.
- You may not post replies
- You may not edit your posts
Forum Rules
