Just saw this and I have the 810
I use serial cable (com 4)
I use aspire on my 4 x 4 router
can you share how you modified PP
and most importantly how you transmit the code to the machine
For anyone out there that has a vision ve-810 engraver without dongle or just dont like the limited vision software
i discovered the machine can be used without dongle and vision software
i used vectric aspire and sent toolpath directly to machine using a modified vision ve810 post processor
it works very well
Do u have the vision dongle or no? If no you can use vectric aspire to create toolpath and send to vision engraver through vectric output toolpath to mschine option
And the post proc u use drpends on your version of machine...i think my ve810 is v2 controller
You would just add a printer to com4 and use windows generic printer text driver
And the only thing i modified in the vectric stock vision driver are the remark lines before the prog starts..itcdoesnt like the remarks...faults out...so i removed them in the post and saved it
If u give me ur email maybe i can email u the pp ...but i need to know ur vision version....post a pic of the front of machine
..that will help
I have no idea which version control.
I do have the dongle
I never thought about doing this before, then I see your post and think, yes why not.
i am not in a big hurry, but would like to explore my options.
https://www.cnczone.com/forums/attac...1&d=1615841635
@Shelby5041
Thank you for your Reply, i cant answer because your Storage Space (PN) is full.
with best regards from germany
