Need Help! CNC 8060Z not detected in Mach3
Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: CNC 8060Z not detected in Mach3
    Feb 2010
    Rep of Maldives
    Red face CNC 8060Z not detected in Mach3
    Hello friends
    Long time member but almost new to posting
    I joined long time ago because of my interest in CNC. But due to money and time issues this never happened until now.
    I was able to get my hands on a new CNC from china.
    Pictures are attached.
    I believe I bought a $2700.00 Rock
    I am unable to get it run. Mach 3 says "No XHC NcUsbPod"
    I asked the seller and they seem to respond through snail mail.
    I have attached the photos of the USB control card.
    I hops some one knows what is happening here.
    Can any one help with this problem, please.
    Thank you
    Rifaa
    Attached Thumbnails Attached Thumbnails CNC 8060Z not detected in Mach3-3-jpg   CNC 8060Z not detected in Mach3-1-jpeg   CNC 8060Z not detected in Mach3-2-jpg
    Member Sterob's Avatar
    Jan 2007
    Default Re: CNC 8060Z not detected in Mach3
    "Mach 3 says "No XHC NcUsbPod"
    This is your clue.
    You need to find the 'plugin' for your particular motion board and copy it into your mach3/plugins folder.
    it will probably be a '.dll' file .
    Did you get any software from the seller? It may be on there, or you will have to Google for it.
    Feb 2010
    Rep of Maldives
    I did get the dll from seller but it does not correspond to the motion controller pcb.
    I tried a lot of dll from google and two dll from this forum but to no vail.
    The two dll from this forum atleast indicates communication error. It can detect that there is a controller when I plugged in the usb. After reset it say com failure.
    I beleive the dll is the issue and I could not find it.
    I am hoping any one has this pcb
    Jan 2007
    This looks like the same board with different connectors.
    https://hallroad.org/mach3-usb-cnc-i...cnc-board.html
    Link to 'dll' is broken but you might be able to google.
    Same problem with a happy outcome:
    https://www.cnczone.com/forums/mach-...-software.html
    Feb 2010
    Rep of Maldives
    All the links are down
    Jan 2007
    They work for me.
  7. #7
    Feb 2010
    Rep of Maldives
    Seriously ??
  8. #8
    Feb 2010
    Rep of Maldives
    The download links are working?
  9. #9
    Feb 2010
    Rep of Maldives
    I have this dll.
    It says CNC connected but when I release ESTOP is say USBMAch communicate error
    Attached Files Attached Files
  10. #10
    Jan 2007
    Quote Originally Posted by R!f@@ View Post
    Yup....seriously.
    Sent from my SM-G920I using Tapatalk
  11. #11
    Jan 2007
    Yup....seriously.
  12. #12
    Feb 2010
    Rep of Maldives
    Then why winrar is saying broken and unexpected end
