Need help with resolution problem!
Results 1 to 4 of 4
Thread: Need help with resolution problem!
    Registered bjwx2's Avatar
    Dec 2017
    Default Need help with resolution problem!
    DIY engraver, running Artcam. When I send a perfect circle to engraver it gives me an oblong cut. This happens with every object I send to engraver. Somehow the output never duplicates the input resolution or size specifications whether I input mm or inches. When I jog any axis with setting of 10mm it will only travel 5mm using grbl controller..
    Update: x and z axis are responding accurately, it's the y axis that's only traveling half the distance of the
    command sent? Would this be a problem with the lead screw?
    Dec 2013
    Default Re: Need help with resolution problem!
    Quote Originally Posted by bjwx2 View Post
    ..........it's the y axis that's only traveling half the distance of the
    I would say that it's a Y axis calibration problem. Maybe the steps per rev are set incorrectly on the drive? Or, the steps / mm are set incorrectly in the controller?
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2017
    Thanks for the reply, I'll check that out!
    Dec 2017
    You're right, never dawned on me the leadscrews might be different as I ordered them all from the same vendor, thanx!
